Elem, da se vratimo na Yo-mobil:
To je hibridno vozilo koje nece trositi vise od 3 litre na 100 km. Primenjena je nova tehnologija na motoru, cisto ruska. Cena izmedju $10 000 i $15 000.
Postoje 3 varijate:
1) Kros-kupe
Тесhпiсаl specifications and standard options:
(options marked with an * allow reducing the саr рriсе)
Dimensions LxWxH, mm: 4065 х 1ВЗ2 х 1495
Concept: Sрогt-соuре with а 4 wheel driче and iпсrеаsеd
сlеаrапсе.
colour: 2 colour standard: base соlоur and the other опе chosen
Ьу the customer.
Seating capaciý: 2+2 (similаr to classic sроrt coupe).
Airbags: 2.
Kerb weight: 650 kg
Gross weight: 900 kg
Drivetrain:4x4
Clearance: 200 mm
Туrеs: R 17 RUN-FLAT (possibilityto continue driving atthe speed of up to В0
km/h after а рuпсturе) (optional R 16).
Dlscs: alloy (optional - stamped)*
cruise control.
ABS
ESR (implemented Ьу the control system)
The body manufacturing technology is based оп composite апd
роlуmеriс materials (detailed information is confidential).
LED lights.
Епgiпе: rоtаry vапе.
Power: 45 kW (60 hp) (по tгапsрогt tax according to the Russian legislation).
Роwеr plant consisting of an епgiпе+ а gепеrаtоr and ап епеrgу
accumulating system, Епеrgу capacity is equal to а 2-litre 150 hp
lCE.
Acceleration to 1 00 km/h:
."ЕСО" mode - ]0 seconds;
."SРОRТ" mode -7 seconds;
."SLIPPERY" mode - ]4 seconds
Fuel: A1-92 petrol / natural gas (methane).
Two fuel tanks capaciý:
.petrol - 20 litres;
. compressed паturаl gas - 14 cu m оr liquefied natural gas - 20
l itres. (optional, а mono-fuel system)*.
Fuеl consumption: З.5 l реr 100 km.
Emission standard: EUR0-5 (по catalyst, methane)
Rапgе with Мо full tanks - 1 100 km
Rапgе оп capacitors'energy (engine is turned off) - 2 km (used
whеп fuel is оvеr оr опlу а shогt distance has to Ье covered).
Тор speed - 1З0 km/h 1limiteo electronically апd ьу legislation),
lNTELLIGENT ё_MoBlLE
. Multifunctional steering wheel.
. Touchscreen сопtrоl рапе|,
. Ап option to choose the colour and design of information panels
(similar to the mobile phones)
. Climate сопtrоl,
. GLONASS and GPS navigation systems. Frее OpenStreetMap
maps which сап Ье edited Ьу the user and downloaded via lnternet
оr USB.
. Control system ensures ап automatic lCE "staгt" and "Stop" if
required.
. Multimedia system includes:
- lпtеrпеt: 4G YOTA, and ап additional provider.
- Audio, video downloaded from ап ехtеrпаl USB storage system.
- Bluetooth phone.
2) Hatchback
3) KombiTechnical specifications and standard options:
(options marked with ап * allow rеduсiпg the саr рriсе)
Dimensions LxWxH, ппl:3В92 х 1В] 5 х ] 6] 1
lnterior ё-сIаss space: B-class ехtеriоr, E-class iпtеriоr.
соlоur: 2 colour standard: base соlоur and the other опе chosen
Ьу the customer.
Seating capacity: 5 rncluding the driver.
Airbags:2.
Kerb weight: 700 kg
Gross weight: 1 200 kg.
Drivetrain: 4х4 (optional,. 4х2)*,
Clearance: ] 70 mm
TYreS: R ] б RUN-FLAT (possibility to continue driving at the speed of up to ВО
km/h аftеrа puncture) (optional Rl5)*.
Discs: alloy (optional - stamped)*.
cruise control.
ABS
ЕSR (implemented Ьу the сопtrоl system)
The body manufacturing technology is based оп composite and
роlуmеriс materials (detailed iпfоrmаtiоп is confidential).
LED lights.
Engine: rоtаrу vапе.
POwer: 45 kW (60 hP) (по trапsроrt tax according to the Russian legislation)
Роwеr plant consisting of an engine+ а gепеrаtоr and ап епеrgу
accumulating system. Епеrgу capacity is equal to а 2-|itre 150 hp
lCE
Acceleration to 100 km/h:
, "ЕСО" mode - -l
1 seconds;
,"SРОRТ" mode - В seconds;
,"SLlPPERY" mode - ,]4 seconds
FueI: A1-92 реtrоl / natural gas (methane),
Two fue! tanks capacity:
,реtrоl - 20 litres;
.согпрrеssеd natural gas - ]4 cu m orliquefied паturаl gas - 20
litres.(optional: а mono-fuel system)*.
Fчеl consumption: З.5 l реr 100 km
Emission standard: EUR0-5 (по catalyst, methane).
Rапgе with Мо full tanks - ] 100 km
whеп fuel is оvеr оr опlу а short d stance has to Ье сочеrеd).
Тор speed - 1 З0 km/h (limited electronically and ьу legislation 1
lNTELLIGENT ё_мовlLЕ
. Touchscreen control рапеl.
. Ап орtiоп to choose the соlоur and design of information panels
. Climate сопtrоl.
. GLONASS and GPS navigation systems. Frее OpenStreettVap
maps which сап Ье edited Ьу the user and downloaded via lпtеrпеt
оr USB.
. Сопtrоl system ensures ап automatic lCE "stагt" and "Stop" if
required.
-lпtеrпеt: 4G YOTA, and ап additional рrочidеr.
-Audio, video downloaded frоm ап external usB storage system.
Svi modeli su vec predstavljeni a Putin je cak i isprobao u voznji.Technical specifications and standard options:
(options marked with ап * allow reducing the car рriсе)
Dimensions LxWxH, ппl: 4200 х 1ВВ0 х 1В70
Furgon concept: maximum load space апd payload with minimum
dimensions.
Colour: 2 colour standard, base - "working" оrапgе and the оthеr
chosen Ьу the customer
Seating capaciý: 2 including the driчеr.
Airbags: 2.
КеrЬ weight: 650 kg
Gross weight: 1 550 kg
Payload:750 kg
Load space:4 cu m, possible to load а standard еurо pallet
Drivetrain: 4х4 (optional 4х2)
сlеаrапсе: ] 70 mm
Tyres: R 16 RUN-FLAT (possibilityto continue driving atthe speed of up
to 80 kmlh аftеr а рuпсturе) (optional R 15).
Discs: alloy (орtiопа| - stamped)*
cruise control.
ABS
LED Iights.
Епgiпе: rotary vапе.
POwer: 45 kW (60 hP) (по trапsроrt tax according to the Russian legislation).
power plant consisting of ап епgiпе+ а gепеrаtоr and an епеrgу
accumulating system. Епеrgу capacity is equal to а 2-litre 150 hp
lCE.
. "ЕСО" mode - 14 seconds;
."SLlPPERY" mode - 1В seconds;
Fчеl: A1-92 реtrоl / natural gas (methane).
.petro| - 20 litres;
, Compressed natural gas - ] 4 cu m оr liquefied natural gas - 20
litres. (optional: а mono-fuel system)*
Fче! consumption: З 5 l реr 100 km
Rапgе with two full tanks - 1 000 km
Rапgе оп capacitors'energy (епgiпе is turned otf) - 2 km (used
whеп fuel is оvеr оr опlу а shогt distance has to Ье сочеrеd).
Тор speed - 1З0 km/h 1limiteo electronically and Ьу legislation)
INTELLIGENT ё-MoBlLE
. Touchscreen сопtrоl рапеl.
. Ап option to choose the colour and design of information рапеls
. Climate сопtrоl.
, GLoNASS and GPS navigation systems. Frее openStreetMap
maps which сап Ье edited Ьу the user апd downloaded via lnternet
оr USB.
. Control system ensures ап automatic lCE "staгt" and "stop" if
rеquirеd,
. Multimedia system inc|udes:
- lnternet: 4G YOTA, and ап additional рrочidеr.
- Audio, video downloaded from ап ехtеrпаl usB storage system.
- Bluetooth рhопе.
http://www.youtube.com/watch?feature=pl ... fesa9Qr1xc
Proizvodnja pocinje sredinom 2012 u Sankt Peterburgu.
Ko hoce da cita o tehnologiji na motoru:
http://www.slideshare.net/onexim/yomobile
