POLOVNI DELOVI ZA SAMARU
Mozda je nekome nesto interesantno .......
ALNASER 1000
ALTERNATOR 1000,
PODIZAC STAKLA 700 PO KOMADU (troja vrata samara)
FAROVI 1000 PO KOMADU,
STOP LAMPE 500 PO KOMADU,
BRANIK PREDNJI 2000, ZADNJI 2000,
MENJAC 30e,
HLADNJAK 2000,
VENTILATOR 1000,
DOBOSI 750 PO KOMADU,
GLAVCINA SA DISKOVIMA, PLOCICAMA I KLESTIMA 2000 PO KOMADU,
AMORTIZERI ZADNJI SAKSOVI 1000 PO KOMADU,
PREDNJI AMORTIZERI SA OPRUGAMA I SOLJAMA 1500 PO KOMADU,
ZADNJI CILINDRI I PAKNOVI 1000,
GUME 165/70/13 PAR 40e,
PREDNJA HAUBA 1500,
PREDNJA SOFERKA 1000,
ZADNJA 1000,
NOSAC MOTORA VELIKI 500,
SREDNJI LONAC 1000,
ULJNA PUMPA 1000,
POLUOSOVINE SA UNUTRASNJIM HOMOZGLOBOM 1000 PO KOMADU,
KORPA 1000,
ZAMAJAC 1000,
MOTOR BRISACA ZADNJI 500,
GLAVNI KOCIONI CILINDAR SA CANTROM 500,
LEVO ZADNJE BOCNO STAKLO 500,
DESNI RETROVIZOR 1000,
STAKLA VRATA 500 PO KOMADU,
BOBINA 500,
PREDNJI MOTOR BRISACA SA MAKAZAMA 1500,
BENZISKA PUMPA NOVA 1000,
KOMUTATOR 500,
KARBURATOR 1000,
RAZVODNIK 1000,
PREDNJA MASKA 500,
REZERVAR SA PLOVKOM 1500,
PODKRILA 2000 SVA CETRI,
ZADNJI MOST 1000,
LETVA VOLANA 1000,
SERVO 500,
VODENA PUMPA 500,
NOSAC MENJACA 500,
5 FELNI 2500,
SAJLE RUCNE 500,
SAJLA GASA 100,
SAJLA HAUBE 100,
KVAKE 500,
Sve informacije na:
Nenad
064/9654-687
062/1687-456
ALNASER 1000
ALTERNATOR 1000,
MENJAC 30e,
HLADNJAK 2000,
VENTILATOR 1000,
PREDNJA HAUBA 1500,
ZADNJA 1000,
SREDNJI LONAC 1000,
ULJNA PUMPA 1000,
KORPA 1000,
ZAMAJAC 1000,
BOBINA 500,
KOMUTATOR 500,
KARBURATOR 1000,
RAZVODNIK 1000,
PREDNJA MASKA 500,
ZADNJI MOST 1000,
LETVA VOLANA 1000,
SERVO 500,
VODENA PUMPA 500,
NOSAC MENJACA 500,
5 FELNI 2500,
SAJLE RUCNE 500,
SAJLA GASA 100,
SAJLA HAUBE 100,
KVAKE 500,
Sve informacije na:
Nenad
064/9654-687
062/1687-456
Re: POLOVNI DELOVI ZA SAMARU
Mene za dostavu preskoci :p treba videti tablu sa osiguracima.
Daj sliku soferke?
okrenes one brojeve i pitas, to je skora usluzno okacio
prednji branik, pod uslovom da je neostecen i da se nije pokrivio od sunca. ima li nade?
Djape, okreni one brojeve tj Nenada, pa pitaj, skora je samo ispisao delove sta ima Nenad.
Imas kod Lakija ...tu ti je na 2km od tebe......mislim da ce ti ga dati na poklondjape1977 wrote:prednji branik, pod uslovom da je neostecen i da se nije pokrivio od sunca. ima li nade?
travelman
Gde se nalaze ovi delovi, na kojoj strani sveta ... i jel ima neko u planu da skoro ide po nesto ...
U sremcici ....sta ti treba ??
mene zaobidjite dok jos koji dan ne pokrenem tenak :p
Ne kapiram te sta stalno vices da te zaobidjemo kad i sam znas da ces svratiti i pokupiti ako nesto treba !!! Sta se bacas bez veze ???
Ne on hoće da kaže da prekosutra se moskva kreše. Ti bre Skoro ništa ga ne ukapiraš.
xaxaxaxa :p :p
travelman
Ne treba mi nista, fala Bogu .... sve radi kako treba .....sta ti treba ??
Mislio sam da ga zovem i pitam za zadnje korube ... da me Dejca vise ne proziva ...
Ali sacekacu jos koji dan da se tenak upali i pusti u pogon pa cu zamoliti Aleka da mi to dotera do nekle ...
zovi pitaj ga da rezervises al cisto sumljam da ima, ne vole svi svoja auto
